country_boy
The Elevation is around 8000' and yes we average around 16-18 feet
R.I.P. little buddy
I’m sorry Marty.
I read the El Dorado fire was started by fireworks at a gender-reveal party.
Over 7,000 acres.![]()
I’m looking to put tracks on my 98 carry. Curious of everything you needed to complete installation. Hub adapters, brackets, lift kit, etc. would appreciate any help!It Lives!
I greatly appreciate you taking time to help. I do not have the truck yet but most likely picking it up Sunday. I’m also curious if you think it is the right route for me. I have property 8 miles deep in Michigan’s Upper Peninsula where they get a lot of snow. The 8 miles is a groomed snowmobile trail with about a 1/2 mile drive off of the snowmobile trail to my property. I debated between buying a snowmobile and a side by side, but think the mini truck with tracks is a better option for me. I’m a little concerned about it becoming a money pit… Trying to build a dependable all weather vehicle on a budget. But, anyways I’m going to go the camso route as it is a little cheaper. Plan on picking up a used pair. Do you happen to have pictures of the anti roll brackets you made? Do you think I could also make the hub adapters? Did you go with the heavy duty springs up front? Is there a thread dedicated to the van build? Sorry for the loaded post.And you need a 3” lift kit. Easily found on the internet. Just google mini truck lift kit.
As long as the deep snow is wet and heavy, my van does great, even 20’ drifts. The Suzuki did well also. Never had an opportunity to get into deep powder, but I imagine it wouldn't go well, likely plow thru it blocking the radiator and overheat. If I remember right the Camso tracks have a lug to attach the anti roll bar to, the front attached to the A arm and the tear to the frame to control track roll, and yes they are necessary, without them you could never cross a ditch.I greatly appreciate you taking time to help. I do not have the truck yet but most likely picking it up Sunday. I’m also curious if you think it is the right route for me. I have property 8 miles deep in Michigan’s Upper Peninsula where they get a lot of snow. The 8 miles is a groomed snowmobile trail with about a 1/2 mile drive off of the snowmobile trail to my property. I debated between buying a snowmobile and a side by side, but think the mini truck with tracks is a better option for me. I’m a little concerned about it becoming a money pit… Trying to build a dependable all weather vehicle on a budget. But, anyways I’m going to go the camso route as it is a little cheaper. Plan on picking up a used pair. Do you happen to have pictures of the anti roll brackets you made? Do you think I could also make the hub adapters? Did you go with the heavy duty springs up front? Is there a thread dedicated to the van build? Sorry for the loaded post.
I did check that out! Cool build. These should work, correct?Yes the van build has its own thread in this section
Those are mattracks, similar if not the same as what is on the vanI did check that out! Cool build. These should work, correct?
Well 6 hour round trip later, I did not end up with the tracks. Had cracks in the track and around lugs. As for the lift, I read that camber can be a problem. Curious if you dealt with this? With a 3” did you need to drop anything to keep everything at a decent angle?Look at the condition of the tracks for rips or delaminating, and the sprockets and wheels with that low of use, they should be like new
What springs do you suggest? I plan on putting a plow on, so was thinking the 300 lb version.Longer stiffer springs for the struts normally come with the kit, I’m not seeing them?
That’s what I have, pretty stiff and should work.What springs do you suggest? I plan on putting a plow on, so was thinking the 300 lb version.
Do you need to replace the shocks? I see you installed air shocks for the van. If so do you happen the have the link to the ones you purchased?That’s what I have, pretty stiff and should work.
