Snowy Rivers
Big leap today.
Got the upper bump stop bracket completed (Except paint)
Some pics of the bracket on the table after welding done.
The bracket bolted back in with zero issue.
Took a 3/8" x 2" bolt and cut the head off....thread it into the forward bolt hole on the cover plate portion of the bracket...
This pilots the assembly right into place easily.
Got the assembly all bolted in.....looks sweet......Rounded off the nasty sharp corners.....Ready for prime time now.
Got to looking at the short stub of axle that sticks out on the inside of the air bag arm.....This area is down in the battle zone...BIG TIME.
Decided to machine a little slip fit cover tube and weld a plate on one end and drill it to allow the center bolt in the axle to secure the cover.
The cover also pulls the air bag arm up tight against the 1/2" through bolt.....The shaft is now protected.....Grease it up really good before the cover is installed and removing the arm should be easy......
That bare shaft would get beat all to rat crap really quick.......Now is a great time to make it a better set up.....
Some pics of the entire assembly from a few angles.
Grabbed a grouser and set it across the front tire to check the location of everything based on where the grouser will operate.
Looks great......Plenty of room.....
