Snowy Rivers
Parts going back on...This time with grease where it needs to be.....
Bolting things down with nylock nuts too....
Some parts were a tad sticky yet....gonna let the paint set more......
Getting the grease adjuster assembly in was far easier than I was thinking it would be.
With the new seals in the cylinder and the parts all together the beast slid down the frame rail easily.....
Fastened the grease manifold in first then stuck the 3/4" bolt through the frame and the rear of the cylinder... (The grease hose is a tiny bit long...so the little manifold needs to be bolted in with the two 1/4" bolts first....then the cylinder shoved back to get the 3/4" bolt though the back head of the cylinder)
An interesting thing came up when assembling the grease cylinder.
The original cylinder barrel (Rusted to rat crap) had a spiral ring installed in the end to keep the piston from over traveling..
The Original piston seals were badly damaged (Lip on the inner edge was cut and mutilated)
Getting the piston in past the snap ring groove takes a bit of finesse using a thin feeler gauge as a tool to gently "Shoehorn" the seal past the groove...
I did not have a tool to cut the ring groove in the barrel....Soooooooo...I drilled 4 evenly spaced 3/16" holes around the barrel end and tapped in 4 roll pins ....These will secure the piston from over travel......
The last crew to have these cylinders out likely used a 5 pound club and just hammered the piston into the cylinder.....thus the damaged seals.
The LH cylinder seal had a huge chunk cut in the seal lip.....The frame had about 10 pounds of grease in it that had leaked out past the seal.......No doubt making a stable track adjustment impossible......
RH side was just rusted up beyond use......
And on we go.
Removed the Zerk and the adjuster assembly slides in and out very nice....
Assembled the inner adjuster and it too operates quite nice....
Inner is a 5/8" coarse threaded unit.....
The Air bag arm is nearly ready to go back on.....brackets painted and still a tad tacky.
I still need to redo the sketch for the bag arm so we can make the LH part the same..... This area had a few revisions as it was coming together....so we need to make the other one the same......IF I WAS TO DO IT OVER....There would be some changes to the design to make it easier to build.....but at this juncture it will remain as is.....
One big change I would like to have been able to do is to have access to a key way broach and made the hub that goes onto the axle at the bag arm a custom part to my specs instead of adapting parts.
This time through... the red bushings are going to get the Super Lube slathered all over them as they go back in.
Same with the axle. Urethane likes to be lubed up to stop squeaks and other unpleasant operation..... The Energy brand bushings for trucks have a silicone lube available......
The custom bushings on the cat are the same material 95 durometer urethane....
That super lube is supposed to be WATER PROOF.....A good thing... and it sticks really well....USE RUBBER GLOVES
Be cool to get the axle shaft hard chromed.....It would last forever .....and not rust....even galv would be good...
It's coming together.....
And on we go.
