Not to hijack the thread, but I'll throw out a couple of thoughts:
When it comes time to replace wheel seals many people go to their local auto parts store or bearing supply company and get seals there. Those seals, made by companies such as CR (Chicago Rawhide, now owned by SKF) and National are usually a double-lip design.
One can also buy seals from Tucker and they're different. Tucker uses a triple-lip design, and the seals themselves use a special rubber compound designed for low temperature applications. They used to be very reasonably priced. I bought a bunch about eight years ago at $2.75 each. Now they're $4.45 per...a 62% increase. Ouch!
I've seen the backwards seal installation technique recommended before, but I think folks are overlooking something in blaming the wheel seals for grease contamination issues.
If you think about the Tucker idler wheel setup (damper wheels, if you have those, are similar), you have a spindle, whose outside diameter is substantially less than the wheel seals inside diameter. Tucker uses short machined steel sleeves called "ring seals". The wheel seal rides on the the OD of the ring seal. Look at the inside of the ring seals pictured in this thread. Here's a pic so you don't have to scroll backwards.
The inside is just machined steel, and it's designed to slide over the spindle. There is no sealing capability whatsoever between the inside of the ring seal and the spindle, and water, or other contaminants, can fairly easily get in and raise havoc with the bearings. Tucker (correctly) recognized this and came out with a revised ring seal design that incorporates a groove on the ring seal ID for an O-ring. That O-ring makes a seal with the spindle. I don't know when they introduced the redesign, but I suspect many Tucker owners are replacing wheel seals when they aren't the problem at all. If your machine has the original style ring seal design I'd consider machining the groove and adding an O-ring to your existing ring seals, or possibly purchasing new ones from Tucker. Here's a pic of the second generation ring seal.
