Squerly has been goofing off lately. Concrete should be cured by now to start framing. Of course, turkey hunting will be starting and that will slow things down.![]()
North Carolina????,,,,We are talking turkey now,,,,and Bear if I'm not mistaken. Half the guys on the contruction crew will be in the woods
Weather permitting we will start framing on Monday!Good news on the inspection, i cant wait until you start building the house.
Wait until you see the cool compass I will have imprinted in the downstairs patio cement! Pics tomorrow!Thanks for the pictures. Now, with the added pours, the design is starting to make more sense.
It's there, I just didn't post a picture with the proper perspective. I'll lift the boiler up and sit it right over the water pipe, which is now just draped over the furnace. The pad was originally 15' deep and 25' wide but I cut it back to 10'X25' because I wanted the extra 5' for the driveway. Helps me back my truck back around that area. And I still have 4' of concrete in front of the furnace which I feel should be enough room to keep my feet out of the mud.Where is the notch for the pipe and electric for the boiler? You do have the pipe in already I hope.
I've got room for a genset and the rest will be for wood. I'll have walls on all sides except the front so the wood should stay dry and it'll be easy to work with.What is the rest of the pad for? Woodshed? What had to be inspected? the walk?
This coming from a man who's flag is upside down...Should we tell him his compass is off? On my computer it's off by about 20 degrees in the first pic.
Dear Color-Me-Curious. This is special wood designed for one-time use. It was chosen especially because of its kamikaze traits and it will now spend the rest of eternity wedged between two concrete slabs. But don't feel bad for the wood, it knew its fate going in as only volunteers are accepted for the job. Thank you for asking!Squerly, whats becomes of the 2X4's used as forms along the existing floor slab? ... just as well, the 2X2's used earlier as forms for the floor pour along the foundation wall? A fool-proof form to hold grade, yes, but are they to be left in place?
Color me curious.
Sounds good to me. Been around the biz a long time and just never saw that before. I guess termites were an issue where I worked in the South and Mid-Atlantic. We always used a form-grade expansion board as the grade line along walls and slabs.Dear Color-Me-Curious. This is special wood designed for one-time use. It was chosen especially because of its kamikaze traits and it will now spend the rest of eternity wedged between two concrete slabs. But don't feel bad for the wood, it knew its fate going in as only volunteers are accepted for the job. Thank you for asking!
Thank you Kane!Gonna' be a beautiful home, squerly. I bet you're havin' a ball.
It is an expansion joint. I would have used treated outside though.Dear Color-Me-Curious. This is special wood designed for one-time use. It was chosen especially because of its kamikaze traits and it will now spend the rest of eternity wedged between two concrete slabs. But don't feel bad for the wood, it knew its fate going in as only volunteers are accepted for the job. Thank you for asking!
Not to worry Mule, we only allow treated wood to volunteer.It is an expansion joint. I would have used treated outside though.
Yep, it could have been worse. I think I am done with hydroseeding. The grass doesn't germinate any faster and if a storm comes through it wipes out the whatever you happen to have done anyway. So spending the money on HS hasn't really helped me much. I would have been better off to toss some seed and throw some straw over it. Oh well, live and learn, right?Look on the bright side, the swale worked. I have some wash on my lane from the cloudbursts we had. It is a swamp in the garden.Might want to try some of that coconut matting. Probably cheaper than hydro seeding.
