Sno-Surfer
Well spent most of the weekend getting to know the Snow trac and scratching my head. Here's what I've come up with so far.
I've been reading a lot on here, read almost all the manuals posted. I've decided that my snouty nose is something factory made. It's missing the bumper but the chopped off nose for whatever reason sure appears to be a factory mod. I'm also thinking mine is about mid 70's. There are no signs of the usual id plate to the right of the door, only one on the left but nothing is stamped on it, so just guessing on the year. The power disc brakes, I don't know about those but the ebrake unit also appears to be factory and a bit different than the norm.
My other observation, I have a project on my hands!
But it's ok, I can handle it. Lot's of good stuff on this, just needs some love and fine tuning.
I took Dons advice and just slid the motor forward so that I could look in at the throw out etc to see what's making the grinding noise. Throw out bearing is fine, the flywheel seems to have enough clearance and so does the ring gear. I don't know what is making the grinding noise but without taking the pressure plate off, it looks fine. I am wondering if it's rust build up or ??. It' has been in the rain and I'm wondering if I ought to just use the clutch as is for a bit and see if it quiets down. I actually think it might be already the little I've drivin it in and out of the shed. It's all newish, throw out bearing, pressure plate and clutch.
The one problem I have is that my exhaust goes all the way to the back and it's all one piece, even welded to the muffler. No way to take it off unless I also remove the whole muffler. I'm going to take it to the muffler guy and have him put a coupling in there so I can take the motor out if needed. I spent a lot of time trying just disconnecting all the clamps so that I could slide the motor forward just enought to see in the bellhousing. It's back together now.
I now have a trailer too so I'll bring it in to get those adjuster nuts taken off. I need a better wrench than what I have. Those gears are really eating the tires. I will need to put at least one big new tire on.
How about grease? I read in the manual there are about 4 different types of grease used. What do you all use for what parts? I feel the need to grease everything. I hope I can keep it to one or two types of grease.
Also, it looks pretty tough to adjust the valves on these. Do you guys adjust them once a year or ?? And can you do it with the motor in the Snow Trac? Just looks real hard to access.
More questions to come.....
Thanks again for all the help.
