Sno-Surfer
After finding out about these Snow tracs just over a month ago, I for some strange reason, felt compelled to get one. I've never heard of them and don't know anyone that has one. I just want to use it for fun. I plan to fix it up and make sure it's reliable and take it to the Mt Hood or Mt Adams area. I live about 45 minutes from each. I do have some VW knowledge and have two busses with the same drive train as these. I can keep those running and figured that would help with these.
I was looking all over for one and then three days ago one popped up on Craigslist only 5 hours from where I live. It was at the top of Steven Pass and was used for the last 15 or so years to go 1/4 mile to access a cabin. The guy I bought it from, bought it from his neighbor about 6 years ago. He didn't know the year or vin #. I just bought it as is. It has a rebuilt engine and it runs great. The clutch is grinding and I'm sure I'll have to pull the engine soon to fix that. Hope it's not much harder than my bus. Also the chain tensioners are frozen and the passenger side neads tightening real bad as it skips and the gear has worn a groove in the front tire because it's pulled back so far.
Can you fabricate a new tensioner and cut the old one off? They didn't look too complex. The PO said, don't even try, it's frozen, they've used heat and messed it up more." Looks ok on the side I need to tighten, the other side has a piece cut out of the bolt. But he said they are both totally frozen. Sure, I'll try anyway but thinking ahead. I have no welding skills.
I have two front tires and two boggie tires and one boggie hub as spares. Tracks look ok to my untrained eye. He said he rebuilt the boggie wheels (hubs) and foam filled the tires. It has disc brakes in the front. The hood has been reshaped a bit and looks more like a snout.
It's hot wired and I need to find a diagram if there's one available. It needs a new switch as the PO lost the key. Once the switch gets fixed I think the rest of the wiring needs a little help here and there but seems that most everything works.
I have barely driven it. Just a couple loops around the parking lot and on the trailer and up my driveway. I need to fix the chain tension before I really drive it. Clutch too, don't think it's the throwout bearing, sounds more grinding.
More to come, I'll try and post some pics. It might take a day to get the pictures sorted out.
This site has been great. I've read a lot on here and that's about the extent of my knowledge. Now I have one in my driveway. I'll have a lot of questions and would welcome any information or opinions, parts sources, or anything else anyone wants to offer. Thanks in advance!!
