Then the bearings were drilled and tapped for the grease zerks, and a new bottom shield plate identical to the original one was attached.
as much as I like to restore to original specs, I would not put the box back on, but rather create a storage area in the coffin and have a hinged door in the floor of the flatbed, the coffin area is just wasted space, unless you take the fuel tanks out of the cab and built a custom tank in the coffin area, thus giving you more room in the cab, that would be the best choice IMHO.
thank you for posting the photos of the restoration.....
Built the new thrust washer this weekend for the front of the trunion pin. Also built a thin washer for the aft end of the pin to take up axial slop and give a better thrust area than the back side of the trunion hold down clamp was doing.
Here is the pin before the washer was installed, I had to machine the fillet weld down a bit so I could get a good perpendicular thrust face on the angle head of the trunion pin.
Here is the new thrust washer:
Here it is installed:
Here is the thin washer on the aft end, just next to the roller bearing, everything is tight now, but not to tight, slop is gone and good thrust faces are now in play:
My recommendation would be to use a wear metal for the thrust washer surfaces for long term service.
That current setup if all the same material will wear your fine work over time causing you to redo it all. Although maybe not until the next lifetime.
McMaster Carr should have what you need like a bronze or hardened bronze.
Check out my 1443 thread for what I used.
If you are looking for bomb proof, here is another idea to beef up the trunnion cross member. Also, turn another trunnion roller to decrease the wear on the fifth wheel. Better to have two rollers, as shown, as they will revolve at different speeds. One long one works too. Splitting of the hair.
Agreed on this. That is a massive amount of Sno-Cat to only be able to carry two people inside. This is 'coffin' option:
That "coffin" option is way cool, I now understand. This one I am going to have to think about. One issue I have is this is where the exhaust pipe and muffler were located, if I go with this option I will have to figure out a new path for them. Now for my personal dilema: I want to keep this unit close to original, that is what I did with the Frandee. After 8 years of working on the Frandee to keep it original (as well as I could) it has tainted me. I don't want to ruin this machine by making significant modifications. When I get in it to drive I want to feel like I am still driving the same unit they made back in 1966. Sappy, ya, but that is the way I am. Also, this may sound crazy, but eventually I want to make a camper I can place on the bed. I think that would make for a great adventure rig. Take the Tucker and the Frandee, leave the Tucker as base and drive the Frandee around, or whatever. Dreams dreams dreams.
Now for these great ideas that have been coming my way like the "coffin" and the improved trunion, and whatever else may pop up, well I bought the Tucker frame from the 543 this spring up in Washington, then I bought the 500 series pontoons from the Tucker factory. Now it looks like I may not be using many of the parts from either of these purchases on the 543CF. So what does this leave but the makings for a custom Tucker like snowcat from these extra parts, hmmm the ideas, I need to get retired so I have time for all of this.
In the vintage car world, that is the equivalent of "Unobtainium" on the patina scale.
Whats the stone sub-surface building with a chimney...back entrance to the bat cave or a speak easy?
…… looking good , the transfer case assy. is not a complicated unit... each shaft has a ''preload'' spanner nut for adjustment... I fabricated a socket to fit spanner's ,... is that an old JD 1010/1020 ?? in the background ...
Yes, that is a 1964 (same model year as me) JD 1010 I rebuilt several years ago. It is my main work horse, could not rebuild these snowcats without it.
Now I have some questions for you, if you don't mind helping out a bit, or if anyone out there has some helpful info I would very much appreciate it.
For the transfer case, I am researching what preload to put on the bearings. It appears the newer 2000XL model uses .001 to .003 inches of clearance for the bearing endplay between races. My research using the TIMKEN manual indicates .004 to .010 inches of clearance. I thought about calling Clyde at Tucker and seeing if he would provide what they suggest for a 1966 transfer case. The research indicates you want to have near zero endplay once the transfer case is warmed up to operating temperature. I imagine that the slow speed these gears turn that the case does not heat up much. Therefore, I am leaning toward an endplay of around .003 to .004 inches. When I took the case apart one of the bearing races for the center shaft had a couple of small spots where the race had spalled off. It also looked like the nut used to set the preload (move the race in) had backed out slightly, as the center gear had started to touch the aluminum case. Damage/wear is minimal and inconsequential.
The two case halves were assembled without use of any sealant. I see on the newer cases the factory uses silicone sealant, I am not sure I like this idea. I have had some bad luck with silicone before on this type of seal. I am considering using some different Permatex form-a-gasket type material, even thought about using copper coat. Any suggestions.
I am working to calculate the torque I want to use on all the fasteners and the tightening steps and sequence. Should have that figured out before to long.
Planning to order the bearings and seals this Friday. Still have to get the races out of the one side of the case, figured I would weld a bead around the internal diameter of the race to shrink it and free it up.
I have the wrench to adjust the nut which is used to preload the bearings about 80% built, should work well. Will attach a picture of it when I get it completed.
If you look to the far left center of this picture the center bearing race damage can be seen.
Here is the minor wear on the other side of the case where the endplay was to much and allowed the gear to travel into the case. This preload nut was found to be loose when disassembly was being performed.
…. can't quite see your powerplant,... whatcha got there....
…… hello G,... yes, the 1010 is one of the rare engines , that all 4 sleeves are attached to the top plate ,... when we did ours, we had a hell of a time getting them out, pretty sure it hadn't been apart before,.... I was actually asking about the engine you had hanging off the loader ….I am assuming you are talking about the JD, it is a JD 4 cylinder gas engine. The one that the cylinder sleeves all come out together as one unit.
Thank you very much for the transfer case rebuilding information.
