It is time to give an update on the 542CF restoration, sorry for the loooonnnggg delay since the last post. First I lost both my helpers, son 1 got a girlfriend and son 2 decided to join the Marines.
Since the last update most of the engine machining has been completed and major parts have been procured (some are very hard to come by for this engine), but I will save those details for later, since I am currently working on the frame.
I have also procured the 543 frame from the Spokane Washington area so that I can use the rear trunion plate. Mine is on the front and had been damaged at one time and scabbed back together. I haven't taken this one off the unit yet, but it looks like it will work.
I also purchased the 500 series pontoons from the Tucker factory, leftovers from their most recent vintage restore.
"Mine has three right side pontoons",
the left rear was replaced at one time. So with these pontoons I now have the correct pontoons. Looks like one of them will work, will know more later when I get it torn apart. If not, I have spares.
Thanks for the clarification on the pontoons! That will help when I start working on them.
Thanks for the advice, I will open them up when I get ready to rebuild them. The steel is in fairly poor shape as it is so most likely they will be needing a lot of it replaced.
Need some help from the Tucker experts out there.
Does anyone know what aluminum alloy the fifth wheels are made of, and if any heat treatment was performed on them after casting.
they were Red !
but pretty sure yours did not have racing stripes, the machine in the photo, probably was the only one or two, ever to have the go slow stripes,
they are cool and look good, I myself would do the stripes, but wide ones, like from a '69 Camero
but you can always call Clyde, he is the man/expert with all the answers...
no expert here, just a minion,
I have a 542 and the box is aluminum. fyi, not all cab forwards had the tool boxes.
it is too bad Clyde does not participate on the forums, he has all the factory records and would be able to answer these questions with some authority, it would be an asset to the collectors of tuckers
I will make the new one from aluminum then. It is obvious to me that this one had the box, there is an opening in front of the plywood bed but behind the cab. And there are old bolt holes in the frame in this area. Thanks again for the help!
Here they are all welded in. Next will be to ream out the bearings back to size. Welding shrunk them, the amount oversized we guessed on was not enough to allow post-weld clearance, plus they are not as round as before. Adjustable reamer is on order, should be here next week. Once the trunion pin fits in the bearings I will drill and tap both bearings for the grease zerks.
There should be plenty of material on this trunion support and rear frame area now to prevent breakage. Maybe a little excessive, but oh-well. I will just have to make sure the machine is moving prior to steering and it should last, I guess.
