I rotated stock on food and water for 6 months, earthquake preps.
Got my emergency communications up and running on 900MHz.
It was a good day.
Tweeker
every day there are earthquakes here in California, just the news doesn't report them.
Another thing that I've found useful on quite a few occasions is a 2000 watt inverter. It has 4K surge watts for around 10 seconds. It'll run all 110volt household appliances easily and, using diesel, I can power it from the tractors or the truck without having to think about draining gas from the vehicles.
Could you tell us a little more about the power invertor you are talking about Frank? Can they be used to power refridgeration or freezers if needed running off my tractor?![]()
Thats just what i was needing to know, thanks Frank. I am just looking for a backup just in case, as my generators have been giving me the fits when i need them most. The tractors use far less fuel IMO, and i keep much more diesel on hand then gas.That's how I use it Cowboy.
I originally got it (2000 watt inverter) to power an electric pole saw from the tractor battery when I was out in the pasture. I also used it for back-up to the generator(s) for running the 5 fridges and freezers that we have. It'll run any one of them using the tractor or the truck. I don't know if it'll run 2 of them at the same time, that might be pushing it as the compressor motor takes a lot of power to start and I think it would probably be right at its limit. There's no sense in doing that. We used to have a big, honking 25-year old plus fridge that I used as a beer fridge that it would struggle to start. God only knows how much power that old thing needed to kick in the motor but once and if it it got it started it would run it just fine. These newer fridges and freezers are a lot more energy efficient and require less power to start so it manages one them just fine.
I used an old jumper cable to connect it to the battery of the truck and just let it idle. I watch the ammeter and if necessary I have a fast idle on the truck I can use. On the tractor I nudge the rpm up about 1500 and let her run.
The disclaimer is that I haven't needed to use it to do that for quite a while. I still sometimes use it to power a drill or something away from the house when I'm too lazy to haul one of the generators down there. The minimum size that you would need would possibly be 1500 watts but a 2000 watt is better. 2000 watts gives you about 4000 watts surge for 10 or 15 seconds which is usually enough to get the compressor going.
I read somewhere once that a fridge/freezer takes about 800 watts to run but takes up to another 2000 watts to start. That's why I said that a 2000 watt inverter would probably be better.
If you plan on running your computer off of the inverter, you will need to get a True Sine Wave Unit, like a "prosine".
An inverter that produces a modifided sine wave is not well suited for your expensive electronics.
Tweeker
That would depend on the type of ac to dc converter your laptop uses.
What happens with a modified sine wave inverter is that the inverter produces some high frequency harmonics which if the are not filtered out will screw up the electronics.
True sine wave inverters cost about twice as much per watt as do the modified sine wave inverters.
I would play it safe and not run a laptop off of a modified sine wave inverter.
Tweeker
Thats good to know Tweeker, i hadnt thought about using it for our computers.If you plan on running your computer off of the inverter, you will need to get a True Sine Wave Unit, like a "prosine".
Tweeker
So far the ones i have looked at are desribed as (Pure Sine Wave Inverter), is this the same thing?
This is all great info, thanks to all for the info & ideas.Hey Tweeker that's something that I hadn't thought of but running electronics off it wasn't one of the reasons I got it. Just thinking, instead of plugging the computer directly into the inverter, if you plugged a UPS into the inverter and then the computer and stuff into the UPS, would that filter out some of the "noise" and allow you to run them safely?
Zoomer, that's a pretty neat set up. I have two deep cycle 12v batteries sitting in boxes that I tote around when pulling the 5th wheel, just in case. I'm a prepper there too. It wouldn't take much rigging up at all.
Cowboy, that was another one of the reasons that I got it way back when. Like you I always have a darned sight more diesel around than I do gas. So, if "whatever" happens and lasts long enough for me to run out of gas, I can still use the little tractor or the big one for that matter or the truck to keep the beer fridge cold. Gotta get your priorities straight. Nobody likes drinking warm beer.![]()
Thats good to know Tweeker, i hadnt thought about using it for our computers.So far the ones i have looked at are desribed as (Pure Sine Wave Inverter), is this the same thing?
Read post #7 of this thread for an explanation Tweeker. Were lucky Doc was even able to get the forums back up.Yes,
As a side note, this site has been down for almost 2 days.
I tried to access it on friday and saturday but was not able to do so.
Tweeker
Makes it a nice clean portable setup. Sweet. I have been saving up distilled water from my a/c condensate pump for batteries. I also use it in my machinery radiators since our tap water is so hard.
A friend of mine told me about industry grade batteries.
They are 24 or 48 volt and as large as a footlocker.
These things can be rebuilt, there is a draine for the water/acid
the bottom is removable so that the lead particles that normally fall off the plate can be removed preventing the plates from shorting out and the lead plates can be resurfaced or replaced as needed.
Tweeker
Next time you're at the junk yard, look around for an old 12V CB radio. Could be invaluable.
All of these young adults addicted to iPads/iPhones/iWhatevers will simply not know what to do ... other than wander around with millions and millions of other young libs looking in vain for their government to give them more.
You may want to check out that CB radio, if it is a 23 channel you may have problems communicating with other CBers.I still have my Dad's old CB in my car, hooked up and ready to use. Could do for a peak and tune sometime though. I can live without my cellphone, though when the fecal matter connects with the bladed spinning device I think it is good to have to get in contact with family and friend who you may be in cahoonts with as far as prepping/planning. The ones expecting the government to help them out of the doomsday situation will be unfortunatley (for them) left in the dark as I believe the government will be the cause of doomsday.
That being said, we are not nearly prepared enough for the impending disaster which I believe will occur within 50 years. Could be in 50 years, could be tomorrow, hard to say. We have a good amount of dried packaeged foods as well as canned foods and I try to keep a fresh water supply by rotating it between drinking it, and using it to make my coffee in the AM and cook with in the evenings. We have a decent supply of medical supplies, and with Lith knowing all about that stuff it's good to have her around
Regardless it's hard to prepare on a paycheck-to-paycheck budget, and we really only have probably a week's worth of water, and maybe 2-3 weeks worth of foods to get us by as of current. But with me having some money freed up by finally having my car payed off, it will be alot easier to make at least a small hoard of supplies and edibles. I'll keep updated with this as I do more.
