GEAR THAT WILL NOT GO TO ENGLAND
ICEBREAKER Merino Wool 200 Bodyfit Base Layer
Simply put, this shirt is not comfortable enough to go with me. Its a great shirt, but it is a 'bodyfit' cut, which means it is a very tight fitting shirt. I just don't like that tight fit. I want something that fits me, but doesn't act like a girdle to hug me into shape. Its the nicest, most expensive Merino Wool that I own, and it will be left behind.
Point 6 Wool 'Light Hiking' Socks
Its a good sock, but not as good as either the Cabela's InGenius (wool/synthetic blend) or the Darn Tough (all wool) Light Hiking socks.
SOTA MUKA white gas stove
This is a GREAT stove, it really is a shame it won't make this trip, but its a little too big, a little too heavy, a little too much, especially for a trip when the uses will be fairly minimal as breakfasts and dinners will typically be eaten in English Pubs and lunches and snacks will be the only use for the stove. So this, being the biggest, is eliminated. I'm leaning heavily toward the stupid-simple ESBIT solid fuel stove. Its tiny and light and will boil water. Nothing more, just boil water. But that may be all I need to make a couple cups of coffee a day, maybe some oatmeal for a snack, etc. I have NOT yet ruled out the alcohol stove, nor have I ruled out the SNOW PEAK iso-butane stove. The alcohol stoves are simply liquid fuel versions of the ESBIT, they heat water. The SNOW PEAK is tiny, even with a couple fuel canisters its still pretty light and small. It is also more flexible for cooking so its not been cut, at least not yet.
KEEN hiking shoes
Not sure which model these are, but they are not going with me. They weigh more than my new Zamberlan 230 Crosser boots, and they provide less support than the Zamberlan boots too. Plus, the KEENs are also less comfortable, less stable and offer less feel for varying ground conditions. Unless I wear out the Zamberlans, or unless something better comes along that I try (and I am NOT looking) then the obvious choice for me to wear will be the Zamberlan 230 Crosser hiking boots. Simply the best light weight hiking boot I have ever encountered.
KOPPEN baselayer polyester hiking shirts
These are very comfortable shirts, I actually like them a lot and wear them all the time. But they get a funky stink about them, even if you just wear them around the house doing light activities that might raise up a bit of sweat. Any sweat that gets into the material transforms into a nasty funk. No thank you, I don't need 8 days of smelling myself all funky. So these inexpensive, comfortable, sun-blocking, moisture wicking shirts will stay at home. I wish they had anti-microbial anti-funk additives blended into the fabric like some other polyester shirts incorporate. But they don't. So they stay at home.
KEEN hiking shoes
