un like points, if he has weak spark I wouldn't blame the electronic unit. he should be getting proper coil saturation. I would suggest looking at cap rotor and wires if all are good, it's likely he has a bad coil ,and should replace it with one intended for electronic ignition. also what is voltage input to the coil is it the full 12 volts there may be a resister some place causing a problem.
