DIY snowcat build
Lots of load at low speed is a challenge to keep any snow cat from overheating, especially the cab over type.
Well, my build was an oversight. It's hard to think far enough ahead to plan out all the nuances. I made an error and mounted the radiator in a really stupid spot and it was literally blowing hot air right into the air intake for the engine/carbs. I've moved it to outside clean air, and will be adding two big 10" fans to pull heat out further. I think that will fix it. Might also make a cold air intake snorkel of sorts for the engine intake.
Hindsight is tough, especially when you build something in 4-5 months with no blueprint to follow. But that's also the fun part. Tweaking things towards success.
Another *mistake* or opportunity for improvement over the snow folks ignore is humidity. Many folks complain about carbuerators and points when the problem is this giant heat source surrounded by frozen water. Latent moisture and a lack of understanding catches many folks *not aviators* by surprise.
I am really liking your reports.
Im futzing with an air cooled imp. (To avoid the prep i should be doing) And this is my first snowcat experience, that is light enough to actually feel the diff over powering the nonbraked side of the chunk.
When i apply the stick, sometimes the traction of the rig is less than needed to force the planetarys into action. And it turns really quick. As the spiders over run and double the driven or non braked side.
Very cool project! I thought about building something similar a number of years back but ended up buying a super cheap Thiokol instead. It needs a full restoration and will probably end up being more work and cost more than just building something simple from scratch!
I'm about an hour down the road from you, would love to check out your work sometime if you'd be up for that.
Yeah I’ve owned a Bombi and Litefoot but for some reason was dumb enough to try to build one. Time will tell if it’s a mistake;)
Old snowcats, as we know, are cost prohibitive rip offs for 60 year old machines.
Hats off to you…I started with a tub and worked up from there…you started with some tube steel and made it work!
Made a blade. Not expecting much out of an 1800lb DIY cat but it does move snow. Eventually I’ll put HD aviators on it but tired of spending money on this project.
Don’t get tired yet! You’ve just begun!!! I can’t tell you how many change orders I’ve done. All I can say from experience is: don’t cheap out, make it the way you want and figure out the cost later, they print more money everyday!!!
Still tweaking things but getting closer. Building new drive sprockets for a third time, current are a bit too wide. Going to decrease diameter a bit to lower speed at clutch initiation.
Smaller drive sprockets lower RPM clutch engagement on CVT. Brakes are almost too responsive now, turns easy. Been plowing neighbors driveways past few days and working it pretty hard. Almost confident enough to go into mountains soon.
