Ah yess.
The art of change order.....
I have been ridiculed a few times on my project for having so many change orders.....
Trying to come up with a plan that allows off the shelf (Readily available) parts to be used can drive ya nuts.
AS you have seen .....Off to the bone yard....then run home and then....back to the bone yard...
As I have seen several times.....The factory parts were fine when they were in use, but so many parts are no longer available and there are not off the shelf replacements.....
Thiokol...A case in point...... used as much off the shelf stuff as they could (I am sure Tucker and others did too) and standard parts like oil/grease seals and bearings are all still around.....But try to find 12" wheels with a 5 x 5.5" bolt patterns ......NOT
I am currently designing the wiring for the large side view power mirrors.
Dodge mirrors....GM cabs and wiring....Cab does not have electric mirrors or windows...Rear cabin does.......
All the switches in the rear doors are obsolete now......but still work......
Adapting newer GM switches is the answer......NOT TOO NEW as all the late stuff uses a body control module to handle the heavy current and the switches use very small wire.....NOT GOING TO USE RELAYS ON THIS STUFF.
Gotta stay a bit older.....The GM square body has tons of aftermarket parts available.....So off we go....
A have been able to scare up factory/dealer electrical schematic books on the rigs I have for my cabs.....HELPS A LOT
When the rain is pouring down and it's miserable outside.....A lot of engineering happens.
As I have told many folks that have been here and watched my cat take shape.....When you can't find what you need.....YOU MAKE IT.....
Having the Lathe and the mill has made much of my journey possible.....
Your rig is looking fantastic......Keep it up....
