Aktiv small wheel project
redsqwrl
Platinum Patron
I needed wheel 1/2's.
My go to wheel provider is hay wheel. Ks i think.
I spent some time on the phone with them. Followed up some leads.... that yielded some cart wheels from denmark , but no wheel shells.
Master st4 rebuilder posted a link to some cart wheels here in the USA and well $40 later im tooling my 50hr machines up to see what a blind sqwrl can do.
I have enough material to make about 180 of these, but I don't think I'll need more than two or three dozen.
I'm getting these heat-treated, just like the flanges that I made. I have a lot of rollers to replace and I've run out of bolts to recycle........ so it's time to make new ones.
I love my job. :biggrin:
after chatting I promptly went home and started piling up the axles.. I have a coffee can full. I need a pile of 1"
so I spent most of my day looking for cages, I actually found some sources today. Pay is only part of the job.
I've got cages all over the place..... at work, my basement, my truck... scattered all over Antrim County. Someday I should gather them all up and put them in a single coffee can.
I'll never use them......... you've seen my roller design.
HEY,..... look what I found at work!!!
..... Shall I make a few of these?
(1/2-20 thread......... do these fit your Kitten?)
There is need for 3/4 rollers for sure.
..... How many 3/4 flanges did I give you? I remember that there were more than I remembered making. 18 or so?
It will be a while until I really get into gear making these axles, I'm starting with six samples to send to heat-treat. They're gonna grow about +.005, so i'm cutting the threads and races a little undersize. When they come back, I need to ensure that all my numbes are good and then I can get busy....... then I will make a huge batch of 1" and some 3/4" axles. I still have two hardened 3/4 flanges in a drawer at work, so I have a pattern to go by for checking fit and function.
..... Have you seen my latest Halloween costume?
It was a coffee can . Ill get to counting. I wish i could get with the extrovert side of my existance more. I kind of like to hide so maybe costumes and sno (wheeled) mobiles could work.
That was December 2022, coming down off the Mackinaw Bridge in St. Ignace. We do it every year. I'll be there again, this year..... no costume, but I'll be riding my 1979 Chrysler Sno Runner this time.
(I don't recommend putting wheels on a Chrysler Sno Runner....... that was a horrible project).
  • 20220212_125118.mp4
    19.3 MB
That scoots better than i thought. I have a motor seat and controls for one of those.
oooOOOOOOOooooooooooo................. I have one in the basement with a bad crankshaft.
......... Negotiations in the future?
What size wheels go on that Aktiv? Have you contacted snowtrac.com to see if they utilize any tires/sheaves that match original equipment? (That might be expensive if they agree to sell you parts, methinks).
Its a two pc 4x3 wide wheel.
They are around. But, like everything they are thin for lawn cutting duties. Follow rollers ect. The aktiv wheels were heavier and had a couple extra forms along the bead area where the wheel might contact the wheel guide of the track. Some folks put a hard rubber tire in place of the very light pneumatic tire, but im interested in light and nimble
The new snowtrac is a bit of a novelty in my opinion. The price point appears good. Im waiting for the market to reveal wether or not they work well enough. The originals have been performing well going on 60 years
My first "experimental" batch of roller axles went out to heat-treat today!!!
When I get them back (in a few days) I should know exactly how they fit... and will begin making lots more.
I can't wait....... I really need these. (I'm going to have to start making flanges again, soon..... as well).
They're back!!!
They didn't move like I expected them to, so I need to buy balls that fit..... but I have a source on eBay, need 9.75mm instead of 3/8-inch.
Now I can modify my program and start whippin' em out!!!
Currently, the 3/4 roller is really sloppy and I have five 1.0 rollers that are the same..... but I have TWO 1.0 rollers that fit great with 3/8 balls. I'm going to install them immediately.
Tree Rat,...... I mean ... redsqwrl..... PM me your address and I will send you two comlete 3/4 rollers as soon as I get the 9.75mm balls. (Probably 3 to 4 weeks..... coming from China).
Just curious here since we are talking tires. The rear big wheel. Is everyone foaming or just running air.
I run air. Ive come to find ( mostly on an imp) that foam filling fails too. The side rubbing action tears up the side wall and foam. Once this starts the tires come apart and you chuck up the rubberized foam quickly. Its heavy. Its a bitch to clean off the wheel.
I use air and carry a spare.
Well i got the indexing head figured out. Got the wheel halves assembled. #60 of air installed and i think the shells or wheel halves will work in 3-6 places in a st4. I will be rolling some rings and welding them on to beef up the beads. My personal position is the wheel guides will work pretty hard on the tires with out the rolled beads that aktiv used. Those tires are too precious to let that wear occur.
ill be watet jetting the rings to help beef up the wheel centers. For now these light weight assemblies will just go in the upper trac return position
the bottom photo is the sqwrl or tree rat created assembly. (Using an oem hub) im milling and drilling on some tree-rat spindles to see if i can create a standard duty hub solution.
