There must be something with my PC because that frame looks orange to me & NOT USAF blue, I guess I will have to take this thing in and have it looked at
Nice jobthose brake bands look so pretty you almost don't want to hide them in that OC15
The original engine cowling was quite abused with a hole in the top surface. You can see that the heater vent had been highly modified on both sides and the front. I had a new engine cowing made along with the heater vent. There probably was a reason why this vent was so highly modified
Thanks grizcty--weatherby has been a great help! I'll look around the shop and see if I find any spare brake lines![]()
BOBCATTTT
ooohhh.........that brings back painful memories from two years ago when I did the ones on the lamtrack.
Starting to dismantle the tracks. We positioned the track on thier side and one person ran the impact wrench on one side while the other held an open ended wrench on the other--took about 4 hours to remove all the grousers on the one track. I included a couple pictures of grousers I am culling from the restore due to excessive abuse, wear and poor workmanship in repair
OMG!You actually think a 6-series could venture into 'the deep stuff'?!?!
Did that machine that had those grousers on, have air or foam filled tires?
Wow. I've never seen 6-series tracks worn like that before. Surprising given the machine is in better condition than what corresponds to the tracks. Must have been run in the dirt or spent a lot of time pulling Kristi's out of the deep stuff.![]()
"Possibly" somebody at some point in time, traded those (or switched those) "damaged" grousers off of another machine for some good ones off of your machine once it was known your machine was going up for sale. The rest of your grousers look to good to have just several very bad grousers.The tires were air filled. I pulled 6 grousers from one track that had crazy wear and crack reapir. The rest of the grousers looked pretty good with the interior wear pads and welds still intact. The weird deal is that there is both 30 inch and 32 inch grousers on the machine.![]()
"Possibly" somebody at some point in time, traded those (or switched those) "damaged" grousers off of another machine for some good ones off of your machine once it was known your machine was going up for sale. The rest of your grousers look to good to have just several very bad grousers.![]()
Ya--I think you are probable right weatherby. Most of the grousers look pretty good. The bottom wear pads show almost no wear. When we were busting nuts yesterday I did notice a couple grousers had new hardware. Don't worry we will catch the bastards![]()
....I wounder ware Mainer was on or about that time period
Ya...........I'll keep my eyes peeled also for.... GROUSER SWITCHERS
Hay.... I got to thin-ken....I wounder ware Mainer was on or about that time period
because of stattic don't sand blast water blast withsand water mix or find somebody with a bonded blaster for additional safety always clean and purge before you work on it but never trust the cleaning you can test good start scrubbing rust and next thing you have opened upm a rust cavity housing gas.if you have to blast and clean let a professional do it.So does anybody have advice on the gas tank--Sand blast first then get the tank cleaned out or the opposite--get the tank cleaned out then sand blast?![]()
