Kitchen Reno
🤣 all seriousness. I survived a 4 month master bath reno followed by a 10 month kitchen reno. I need help. 😫
10 months is beyond extreme. Maybe you should get therapy? Or a "support dog" for remodeling induced PTSD?
We gutted and rebuilt Melen's 1500 sq ft condo in Chicago in far less time. Still took too long, but mostly that is because I would only work up there a few days a week. We did not touch her bathrooms, but every other square inch was re-done. I am looking at a master bath reno, somewhat smaller than your job, but I'm allocating 2 weeks (assuming I have all the parts). The fixtures and tile are not on order yet.
NorthernRedneck
We finally got around to picking out a few samples for the backsplash. We didn't want the boring plain white subway tiles that most people nowadays seem to go with. So we chose a few different styles as options.
We are leaning towards the middle grey square tiles.
We have decided to hire someone to install the tile as even though I could do it, my back won't allow me to be crouched down bent over all day. Same goes for the range hood. I could do it but lately I can't lift my arms above my shoulders. So I informed she who must be obeyed that I can't do it. At least we have a functional kitchen.
The final doors arrived a few weeks ago and were installed.
I love the "irregular edge" on the square tiles you are considering. The sharp clean edge on most subway tiles looks great in some situations but also can be tiring to see day after day after day. The casual/irregular edge breaks up the lines a bit and I think looks better.
If you go with one of the grey tones, what color grout will you use? Something that matches or something that contrasts?
I did my daughter's kitchen and service buffet in rectangular tile with an irregular edge similar to the tiles you are considering. But she chose an iridescent white. White tile with a glaze that has an irregular iridescent effect. The glaze gives it some character. I would have probably picked a light grey.
NorthernRedneck
We aren't sure on the grout. Thinking of light grey? Seeing as the flooring is irregular grey slate square tiles which is the same as the fireplace in the living room, the middle grey square tiles would tie everything together nicely.
NorthernRedneck
We ordered the tiles a few weeks ago and were waiting for the installer to come give us a quote and take measurements. That happened last week and he said most likely end of May beginning of June before they can begin install. Ok. That gives me a month to get the range hood mounting and venting sorted out. I had kind of avoided it as it involves crawling up through a small roof access to the attic space above the kitchen.
This morning, I was just about to head out to drive my daughter when the guy called and said he'd be here Monday morning. Crap....as soon as I got home I started hauling up everything I needed to begin construction including a collapsible extension ladder from downstairs and got to work. I sorted out the venting and will just bypass the venting in the wall and go straight into the ceiling. Ok. So I marked out where the vent will go on the wall and cut a couple of brace pieces to mount it to once the tile is done. But first I had to relocate the electrical outlet for the vent. I still have to throw in a few staples to secure the wiring before drywall and mud. It only needs to be primed as what isn't vent hood will be tile. Then of course I will have to clear the counters and remove the trim and electrical covers and once the tile is in place, add box extenders to each box to allow the receptacles to sit flush.
