Southern exposure passive like that is a good way to go. Wife wanted something that would keep all her flowers all winter as well as grow the starter plants for the garden. When the sun is shining you have to watch the temps and ventilate or temps can climb quickly.
Thought it was time to give this a bump as I'm finally getting around to THINKING about building one.
Wind is a major factor here so it kinda rules out the normal type greenhouse like pictured below. It does seem to be a perty good buy though for the size so I still am thinking about it. Heres the specs from the add. I also have no clue what to use for heat as we dont have access to gas or propane, any thoughts ?
22'x45' Greenhouse frame for sale - $500
Metal Greenhouse Frame with endwalls, framing for around bottom, plastic with wiggle wire, door, and ventalation fan. Greenhouse frame is still constructed for you to see what it looks like when it is up, and we can take it down as soon as you are interested in purchasing.
Well thats a perty good start, thanks Franc. I know very little about using solar for heat, but I sure am open to suggestions there as well.That's a bargain for sure Cowboy.
As for heat, I haven't much to suggest, except for some passive systems.
Use manufactured brick pavers for pathways to absorb solar radiation. USe a solar powered recirc pump and underpathe radiant tubing to store the heat via water in a large insulated tank. A couple of storage batteries to pump at nite. One 45 watt hour panel should do it.
Use the thing for "extending " your growing season by three to four months.
You're other Greenhouses have the PEk radiante systems so youare halfway there.Well thats a perty good start, thanks Franc. I know very little about using solar for heat, but I sure am open to suggestions there as well.![]()
