Alaska Snow Cat
I would definitely get the automatic transmission. Not that the 4 speed is no good but a snowcat has a small power to ground speed range and up/down shifts frequently when working on a slope or in deep snow. The C model is when they went to the auto transmission and I believe all Cs came with the OC-12.
I also think a plow/blade is much more handy than a winch and if you use the blade correctly will probably never need a winch. If you have to go on any side slopes that get drifted over a blade is a must IMO.
If the towing capacity of you truck is a deciding factor I would then go with a LMC 1500 as my second choice. Not only will you be hauling the cat but full fuel and all your stuff for the weekend. Plus the trailer weight and it all starts to add up real quick. I would want to see some actual weight of the different machines and not rely on brochures or other published data. I have a hard time believing your chart on the empty weight of the 1500 vs 1200 but I don't know for sure.
The newer LMC 1200 probably had more steel, heavier frames? Not sure. There are 4 axel models, 5 axel models, diesels and other issues that make any published weights questionable. The A and B models were known for being light weight but suspensions and transmissions were not as desirable to some, so you may want to focus on the 75-78 models.
