BigAl
Power comes from pressure and 1400 psi is not much most of those systems
Of that age were using at minimum of 2500 to even 3750
I don't recall the pump the KT7 has but it seems it was the same pump used in the cushman trackers with a slight twist on the configuration
It could be many things pump reliefs,motors,low charge pressure,etc
PM me if you want assistance if you have any data from the techs tests from before would helpfull
Well Crap ! The owner said that was good PSI and I took his word for it .
I do not know if that was from the charge pump or from the motors .
I know zilch about hydros .
Now you got me thinking Boggie . Maybe the little hydro pump on the motor is not sending enough pressure /volume of oil to the new Hydros ? That is one thing I did not change as the hyd tilt rams seemed to go up and down ok . Maybe its just getting weak ? I honestly feel the company did a good job on rebuilting them . They are a huge shop at handle most of the hydro work in N Cal .That little hydro pump that feeds oil is not much bigger than a Power steering pump in size .
