Lyndon
Thanks Mike. I managed to omit a basic and important part of any Variator rework one might do. There are I believe 10 HEAVY Steel Bushing inserts. They are ST3014 in the diagrams, and they resemble thick washers but with a 'Step'. All the moving parts that have the 1/2 shafts riding on them go in these. They look like 2 different washers scacked together. There isn't really any good way to lubricate these. Water dripping in thru the air intake slots in the hood lets these get rusted up. All of the shafts associated with these washer like bushings are held in by large cotter pins. The cotter can be SAE or Metric, either size works. Use new ones when reassembling the Variator. The bushings are steel, and the shafts are steel and they tend to rust up. Go to the hardware store or Home Depot and buy a 'Tubing Brush' that is slightly larger than the inside diameter of the washers, I think it's 5/8". They will be in the plumbing department and are for dressing the inside of copper tubing before soldering or 'Sweating' the pipe together. They cost about a buck. Dress all the interior surfaces where the shafts ride. Then "Paint" them with Never Sieze or some good quality wheel bearing greese. A Paste Brush, about 20 cents, works good and is also a 'Plumbing' item used for applying Flux paste to copper pipe. I recomend the Blue Boat wheel bearing greese as it is water repellant. Polish all the shaft ends with steel wool or Scotch Brite pads. A Dremmel or air die grinder with a small wire wheel works well too. You can do this dressing of most all of the variator joints even if your not taking the variator out of the machine. You can usually get at least 5 years of service out of one such lubrication this way. The owners manual had you dripping oil from an oil can on these joints, but one runs the risk of getting oil on the Chives(pulley halves) and on the belt. It isn't very effective, and you want to avoid getting greese or oil on the belt or it's mating surfaces. The Variator "C" Casting, ST25 also carries one of the 1/2" shafts and should be wire brushed out too. All the shafts and joints should move freely. The following is a list of the joints that need to be dressed this way:The arm off the steering box,(has 2 parallel plates, ST1045), the ST501, "Segment" or "Arm", ST7021 Eye Bolts(2), All 4 arms(side plates), ST1033(2), ST7018, & ST7019, and both spring holder assemblies, ST7016, & ST1032. You will be suprised how much better your ST4 Turns and steers with these parts properly lubricated. Generally when one initially disassembles the Variator lincages they find at least one of these joints has rusted up solid. I think I mentioned it before, but just incase you didn't catch it earlier, the 3/8 bolt that holds the ST3008 Shaft/Pin in place should be Grade 8, not grade 3 or 5. And it should have a grade 8 washer where the nut rest against the alloy on ST25. Some ST25 castings had a steel sleve in them that this bolt rides thru. Don't loose it, or assemblle it without this. This bolt is ST6161, and the sleve never had a part number and was not shown in any of the factory manuals. If this bolt has been replaced with the wrong grade of bolt it usually breaks but you can't see it except when your turning the wheel. The effect was that the steering became very sloppy and then eventually led to other parts breaking.It also tended to ovalize the hole in ST25. You can drill it out to a larger size and slip a small piece of steel tubing thru it to dress up a damaged one.
