BoneheadNW
He didn't do it, he has one!beds said:Hey, I'm a bronze member! Did you do that Junk?
Bone
Bu Yong Xie said:Junkman Thanks for the pictures. You didn't get your snake out and take pictures of it just for me, did you?
Not to change the subject of the clogging issue but I have a question.OkeeDon said:The installer is using a trick that I also have used; aligning a screwdriver (or anything else that will serve as a pointer) to indicate where the flange bolts are located, because it's almost impossible to see them while lowering the toilet. The trick with the wax ring is that you have to hit the flange exactly right on your first try, because moving the toilet about messes up the wax ring, and lifting the toilet off for another try may require a new ring.
