Hey, you got your RTV dirty. :StickOutT
That's quite a load. How did it do at dumping? Is the rear suspension bottomed out (frame down to the rubber stopper)?
Are you doing the "emergency brake" trick?my only issue now is being unable to get it in and out of gear quite frequently without having to shut if off. It's my understanding that Kubota has some "new" pressure relief lever now?
Yep, there is a dump valve on the new ones but if I recall correctly, it's not a retrofit item for our 2004's.
Glad the concrete turned out OK.
