turbinator62
Hi. I'm the guy that bought Niksons Imp. I will be continuing to make improvements to customize it for our use as a cabin access vehicle. So far I've added mirrors, removed the mechanical fuel pump and replaced it with electric, made a snorkel with a K&N filter and vented the crankcase to the engine intake. I added low mounted LED fog lights as we get a lot of winter fog in the Ellensburg Wa. area. I moved the battery from the passenger forward floor area to under the passenger seat along with the winch relay for more leg room on the passenger side. I removed the dash and will build a smaller one for more leg room on the drivers side. To overcome the noisy cabin, I installed a Sigtronics aircraft intercom and 2 Astrocom headsets (ebay) For rear passengers I installed 2 Honda civic seats and added seatbelts to all seats.
I removed both tracks as they were running very tight, even with the idler set at the minimum setting. One track had 53 grousers and the other 54. The track with 53 grousers (213 1/2") was in pretty bad shape but the other looked okay but was also tight (214 1/4"). I don't think Nik had a chance to rebuild them as he wanted to use the cat last winter. From what I can gather from the parts manual for the 1402, there should be 55 grousers with 4" pitch. That would make the belts 220". I have belting and will make a 220" track and see if it fits. I can always cut it back to 54 grousers and 216". From my calculatons of 1/2 the circumference of the sprocket and idler at the inside of the grousers (belt diameter) plus 2x the center distance of the idler and sprocket, the theoretical circumference should be 218 with the idler fully back, 220 at the center positon, and 222 with the idler fully forward. That fits the 55 grouser model at 4" pitch.
I could be completely wrong on this, so if anyone has first hand experience, I would appreciate any advice. It will be a few weeks till I commit to cutting and drilling the belts.
I'll have more as work progresses.
