Tesla’s New Record! / Musk Sparks OUTRAGE / California To Forbid All Tesla Sales (???) / Tesla News
So this isn't true because Zero Hedge has not said so?
Logic says otherwise. Garbage in, garbage out...
I'm rather surprised you don't like ZeroHedge, it seems like it would be one of your favorite websites given how much it covers from a far/libertarian right perspective.
I was curious about that so I started googling.
Looks like Elon stated this also I'm curious how accurate. Did you have a source for your statement? I would genuinely like to research this more. When I Google I keep getting Elon statements. Not to say that he's wrong, I'm just curious
Land Use by Electricity Source in Acres/MW Produced
Electricity Source Acres per Megawatt Produced
Coal 12.21
Natural Gas 12.41
Nuclear 12.71
Solar 43.5
Wind 70.64
Hydro 315.22
And another source, basically says wind farms use 200x the amount of land as required for equivalent power generation of nuclear but obviously is taking into account the space between the turbines. As I live fairly close to, and drive thru, one of the largest wind farms in the midwest, I can tell you that they take up a lot of space, literally horizon line to horizon line and beyond as I drive through them for miles.
"traditional" estimates are 4-6 acres per megawatt - seriously more than the assumption - which apparently was generated by folks insisting solar will become technically much more efficient and all the old solar panels will instantly be replaced by the latest more efficient conversion panels . . . .
the 4 million mega-watt/hrs needed is a good number, except . . . . of course, that is "current usage" and does not include charging all cars/truck/semis plus heat pumps to replace . . . and electric water heaters to replace . . . and electric stoves to replace . . .
those "replacements" will increase "usage" by tenfold - per current estimating / methodology.
battery storage does not impact the land area required - actually increases it. ALL the energy need has to be generated during solar hours - whether it is used immediately or stored for later use. and the battery banks and switch gear require land area as well. relying on battery storage increases the generating capacity and the battery storage to cover "having a bad cloud day"
bottom line: 17,500 square miles is not an outrageous over or under estimate _for current usage_
but "current usage" don't feed the greenie dog....
multiple by 10.... that's some serious area needed....
wind farms are having their own debacles.... aside from the energy input to manufacture one, they are failing at a much much higher than predicted rate and essentially at an unsustainable failure rate. there has been no required 'failure rate tracking' - so it's based on news reports and company reporting. altho there is a mandatory failure reporting in the works /?/ approved - which should allow much more accurate analysis of how wind turbines are performing. at present, wind power is having real serious problems living up to the free energy bit. to wit, the Danish company who recently withdrew from a contact to build a mega-offshore wind farm when they were required to warranty the long term economic results. (government interference also had really big smidges to do with it . . . )
as mentioned by multiple posters - way far too much "information" is published by people/organizations/industries who generate "truth" / propaganda based on being seriously invested in their technology.
I believe in ALL forms of energy. Especially the naughty one, Nuclear power plants.
Cheap energy lifts ALL the boats!
Nuclear power is the ticket!
All the problem plants were pressurized reactors of some sort or wacky heat transfer media to my knowledge (yes that might be limited) none of the boiling water reactors have had an issue.
Fukushima was an engineering nightmare putting the emergency generators below the plant essentially below sea level wasn’t the brightest of ideas for an backup power source.
Chernobyl media was graphite do any air that got in to system at the elevated temperatures and you know the result.
Stick with boiling water reactors tried and proven and more simple design.
