FYI, Boggie added this relevant info to that other thread.  In the interest of amassing the info in one place, here is his input.  Thanks again Brad.
			Pressure 1250-1500psi
Something's to consider
Has the pump been changed? To a higher flow ?
Is the return oil filter dirty causing back pressure or not big enough if the pump
Has been changed
Is the steering valve on the front of the seat releasing all the way?
If the pump has been changed the lines, filter, valve may not handle the flow
Causing back pressure
