talk to Ron at car craft inc 951 781 4480 he will likely want some photos as my trans was a bug trans with a van shift cover i made some mods to my cover so i could use the new seal'd bug shifter cover.
Thanks DDS,
I found a 3.88 to 1 ring gear set. I have not been able to find a 4.10 to 1. I will go this route! Just ramping up on finishing my Snow Master. Ive put her on hold to long. I plan to have her done before snow flies next winter.[/QUOTE]
Well I hope to God you keep us up to date on it and get it done . You don't see me twiddleing my toes and wasting time.
Good to see your "sorry ass" posting again , Mouse Ears . I have not had anybody fun to poke at in a long time . These other Right wingers , gun nuts and snotty Trackers are just a royal pain in my ass , but don't tell them I said that .I like me best
Welcome home .
Snowcat Ops,
The 3.88 gear set will only gain you a little over 4% more speed or only about 19.5 mph vrs 18.4.....
The driven gear in the final drive chains is the one to change I think, but also the front large sprocket can be changed as well, easier, but will not provide the ratio change per tooth as changing the small drive sprocket will.
Now for some real information by someone who knows.....are the splines in the drive spockets metric or english in measurement? And is it commonly cut into shafts today? What is needed is a broach to push through the spocket hub, cutting the splines. I have read that the drive chains are NOT S.A.E .#80 roller chain, but a metric chain instead. So where would one go for a chain spocket, to fit this metric chain....?
So many questions...
