Back to the snow cat pricing:
The two most important and expensive parts in a controlled differential snowcat are TRACKS and DIFFERENTIAL
If you would need to put all new cleats on a track new cleats range from 25.00 to over a hundred dollars per cleat on the big cats times at minimum of a 100 for a machine
Then the belts and backers and tire guides the tire guides are the ones that add up fast especially if they are the style that has two per cleat now you have a minimum of two hundred of those per machine and 20-60 ea
Depending on machine a minimum of four belts (except Tucker's and some with snowmobile type tracks )and some more at a minimum of 200.00 belt and up to over a thousand per belt on some.
So with that tracks are expensive but last a long time if taken care of sunlight and weather are there biggest enemy's along with sharp rocks
A complete new set of tracks can run from 7000-35,000 depending on machine
The differential comes in as the next most expensive consideration internal parts
For them if even available are going up for example the Bombardier ring and pinions which used to be 585.00 a set twenty years ago are now2950.00
A rebuilt center chunk from the facotory now 10,000 with a 3000 core if you don't have one .
Engines and transmissions comes next rebuilt units if needed for the package 2500-3500
Wheels tires, tire fill bearings, good tires 6-10 ply add up 100ea. And more is common
Tire fill at least 50.00 a tire
Bearings minimum 300-500 machine
Wiring gauges seats
Wiring and Gage's easy couple hundred to 500.00
Seats at least 100.00 for a simple one up to 300-500 for the big cats
Paint body, I once took a cat to body shop because we were way behind a small
Cat like a 1404 imp and when they gave me a price to remove the old paint fix some dents and prime a repaint it was 6000.00 well we did it In house we sold the cat for only 7200.00
When it comes to Tucker's the old style the main thing is track rollers that is the most costly fix. If you could even find them good ones 40/45 ea. times hundreds
The newer hydro cats can be a ton of money not only do you have the tracks to consider but also the hydro pumps and motors can be a nightmare in cost hiding
Just waiting to be a problem. Minimum 10k and up to 40k for repair if the system was trashed
And this is if you do the work and repairs yourself otherwise think higher
So when you find a good cat for around 10k and the tracks and differential is good it might be a very good deal.
