I hate to bother the group again. I got everthing back together and installed the tcase without the front and rear driveshafts, just to tranny to tcase shaft. Mainly to see if it was leaking oil. I was surprised how much noise it made when it was turning. During normal operation it may not be noticeable with all the additional noise from the differentials and the tracks turning. I was happy with the build, it was silky smooth to turn by hand and the freeplay on the new bearings was set to .002 as recommended. The gears had no wear or pitting on the contact faces. Question: Is it normal for these cases to be somewhat noisy?
One thing that bothered me when installing the gear set was if they were matched to run in a certain orientation. The center and lower gears are symmetric and can be installed with either end shaft facing forward. I did not see any obvious markings indicating the correct orientation. At the time I convinced myself they were symmetric and didn't matter. I hope it does not have to come out again. It is a PITA. Can anyone shed some light on the situation? I hope this is clear, if it isn't please send me a PM. I can include some sketches or something.
Tacoman,
One of my very best friends is basically a gear cutting genius. His business has different dimensions, but he reverse engineers gear systems, he sometimes manufactures gears from raw steel, he cuts gears for other companies on blanks or parts they provide, he manufactures parts for old gear shapers, and he also services gear cutting machines; both gear shapers and gear hobbers. He knows a helluva lot about gear design, as well as manufacturing gears, and I reached out to him….
He explained gears in a transfer case can be either spur gears or helical gears. Spur gears are also called straight gears, and they are inherently noisy. The noise is a function of the amount of tooth contact between mating gears. The greater the amount of teeth in contact, the quieter the gears. Helical gears by definition have greater contact amounts than spur gears, and are thus quieter. Spur gears are less expensive to manufacture than helical gears, and I’m quite sure Tucker uses spur gears in their transfer cases. (However, to be fair to Tucker, it may not just be due to cost. Helical gears have strong axial forces and that requires more robust cases or housings. The Tucker proprietary transfer case is basically two aluminum castings bolted together and I’m not sure that’s robust enough for a helical gear design.)
My friend explained the amount of gear to gear contact is expressed as contact ratio. By definition, the minimum possible contact ratio is 1.0. A contact ratio of 1.3 is significant because below that number there is more gear noise, and above 1.3 gear noise is appreciably less. He said that in some transmissions in newer cars the contact ratio is 2.0 and they are very quiet and he also said those gears are made to very close tolerances. An automatic transmission typically uses planetary gear sets and they are very quiet. Over the years gear train noise has become associated with either (or both) poor design and lower quality gears.
To illustrate spur vs helical gear noise, my friend explained the manual transmissions installed in American cars and pickups in the sixties and seventies used helical gears for the forward gears and reverse gear is a spur gear. That’s why when you are in reverse, and especially if you go faster than a crawl, you hear a gear whine noise.
I hope this explains the transfer case noise.
Note: My friend sent me a link to a trade publication discussing gear noise and gear design methodology to reduce noise. I think one would have to be either an engineer with an advanced degree, or a serious gear nerd to understand all the formulas and design elements presented. Put differently; way over my head….
