Pond reclamation and right away mods ……
Big Dog
Large Member
I own between the red lines and everything right. Finally got the power company to do some clear cutting. The blue is/was a pond (currently has level but not much) for years until beaver moved/or someone killed them years ago. White is where the dam was and the out feed for the pond. Pond is fed from a small creek coming from the left and a few springs on the right, notice how steep it is on my side.
I’m bringing in a dozer to shape the right away. Right side is high, left is much lower. Trying to figure if I should slope it all or just manage 2 levels. Look close enough and you can see the buggy path coming down towards the pond, it sorta splits both levels. Right-away is approximately 6 acres.
Seeking thoughts and recommendation. TYIA
bczoom
Super Moderator
Not exactly sure what you're asking.
One thing you should consider doing is putting a "silt pond" on the side that's going to feed from the creek. Can't speak for your springs but mine don't get muddy.
When I say "silt pond", I'm talking about a small pond that's going to take the creek water before it feeds into the main pond.
This silt pond will collect any mud, debris or otherwise and collect it there so it doesn't go into your main pond. You then run a pipe or an overflow to the main pond.
When I say small, I'm thinking about something around 20' diameter. You want to make it small enough that you can get into with a backhoe or excavator. You can then scoop the silt/drudge out easily as needed (every few years, give or take depending on how much stuff comes in).
Big Dog
Large Member
Prior the pond was always pristin. Feeder is over rock bottom creek but I research.
I’m asking if I should slope the whole rightaway top right to bottom left or leave the 2 level ridge that divides both. It a double rightaway, 2 sets of lines. Right one set higher than the left one.
bczoom
Super Moderator
Who's operating the dozer? If you're bringing in a driver, I'd get his advise. On that slope, erosion control may be a major factor.
Oh, and what does the power company say about what you're allowed to do there?
tommu56
@Big Dog check out Dirt Prefect channel on youtube he built quite a few dams on there.
Not that I'm an equipment operator like Mike or even close but he stresses the "key" in the dam to seal it off all rock , rooth paths has to be removed and sealed with the right dirt (clay).
A good excavator that knows soil types will be your best alli.
Big Dog
Large Member
Both companies know and haven’t mentioned issue.
Big Dog
Large Member
I have plenty rock, clay is close
Big Dog
Large Member
Refer to my previous picture. This is what I woke too. First is from the house side and second is looking at the the house side.
Big Dog
Large Member
In the bottom …. Not noticeable but the bottom has numerous finger feeders approx 16” wide 2’ deep. Started to plug up a bunch and blocked off the outfall. Bringing beavers in upon level, see how it goes. If they don’t do something, we’ll do a filled outfall.
Big Dog
Large Member
One day of rain in 2 1/2 weeks. Waters holding, dirty from all the dozer dirt moving!
Big Dog
Large Member
After studying beaver relocation found out Summer is a bad time for it. They are taking care of kits. Fall and Spring are best. Don’t really need them now with the dam breast built. It’s starting to fill up too. It was pretty clear before yesterdays 2 1/2“ of rain ….. put some scrap in for critter cover, I plan to stock with at least some bluegill.
Big Dog
Large Member
I need a day or 2 of rain to get to the overflow. Ended up being double the size of the original, just about 2 acres now. Currently rising about 1-2 inches a day just from spring and runoff collection feeders.
J5 Bombardier
Beautiful pond and the fact you shored it up without the help of those furry varmints., it will be clean . Spring fed and stocked , nice .... nothing worse than "beaver water ".
