PHOTOS: "You are doing it wrong" II
Plywood has incredible tensile and shear strength and cladding the corners of the structure, plus a couple strategic points, would have prevented this. They will probably use a couple loaders to 'push' this back into shape and then reinforce it. Somehow I doubt the walls in this home will ever be plumb.
I saw a building in Indianola IA put up three times and fall over three times.
At the time I was building a 36' X 54' barn in the same area.
It stood, no problems.
All it takes is plenty of properly installed braces temporarily fastened to the stud walls.
All stud walls are supposed to be stabilized via braces in order to make and keep the wall plumb and square until sheet lumber is installed. Standard practices.
