weatherby
Old Trucker.....I will try & help you post your pics......The FIRST thing you have to have is your pics. stored on your PC. Now when you want post a pic. you first type in your text like you have been doing, when your done with that you scroll down on that same page until you see MANAGE ATTACHMENTS then click on that, then a box will come up with six (6) BROWS box's you click on the first one (or the top one) then a menu will come up and in that menu will be where your pics are stored (you have to know what title you stored your pics under) then click on that title and your pics will appear then click on the pic you want to put on the forum and then your screen will go back to the box with all the BROWS box's and you repeat the process if you want with a second pic you can do this up to six times or (six different pics) or just once (one pic) Now when your done installing your pics you click on the UPLOAD box and give your PC some time to upload your pics When it's done you then click on the SUBMIT REPLY box under the box where you have wrote all your text and again give your PC a little time to do this, it should be less than a minute. One NOTE to remember BEFORE you post any pics you should EDIT them and what I mean by that is you need to re-size them and how you do that is when you are at your pic you want to post RIGHT click on it and a menu will come up, click on EDIT then you will see where you can (RESIZE custom width x height) and in the first box or (the left box) I type in 800 and it will fill in the right box for you then click OK then click on the X at the very top right corner of the page then it will ask you if you want to save the changes and you will hit YES then it will go back to your pics and NOW when you click on that same pic to select it, it will be at the correct size to fit the forum page. I should say you only need to RESIZE your pics if your camera takes your pics with dimensions greater than 1000 and you can find this out by just putting your curser on your pic and it will give you all the info on that pic and if you see the dimensions at 900 or greater RESIZE down to 800 if your pic is already 800 or less then you will NOT have to resize to make them fit the forums page. This is what works on MY PC. that runs VISTA, I hope this at least gets you in the ball park, Hopefully somebody with more knowledge in computers can lend some help also. Let me know how far you get before you get stuck, then we'll go from there.
Kevin
Kevin
