I could fix that for you for a price??![]()
Next, check your fan motor for an oil port and oil if required. Follow manufacturers instructions! Remember.....don't over lubricate the motor bearings. Usually, "a little dab will do ya"! Too much oil can spill over onto the motor windings and cause a short.
I can afford the new furnace and A/C, it's the cost of adding insulation to a 100 year old farmhouse with plaster and lathe walls that I can't afford.
Keep in mind, there are usually two oil ports on the ones that require oiling.
your Heating and Air Conditioning Company can sell you a new motor.![]()
Two things I want to add. You all notice Cityboy when spraying the coil is in all pictures but one spraying from the inside out. That is good. In one picture you might think he is spraying from the outside in which you don't want to do. But he really is just spraying the lifted dirt down and not back in deeper. The coil type he is cleaning is whats called a "Spiny Fin Coil" They will typically catch more dirt than the "Fin and Tube" coil and is much tougher to get the dirt out of it. Some techs will take a vacuum cleaner first on a Spiny Fin to get as much out as possible first.
A Fin and Tube Coil is much like the radiator of your car and yet it still needs to have the water sprayed from the inside out.
murph
Take your time and don't get in a hurry, and wait to reward yourself with a beer AFTER you have reassembled the unit and it is running again.![]()
Yeah and if you put more than two or three drops of oil in them spots per year your Heating and Air Conditioning Company can sell you a new motor.![]()
In that case, why didn't ya move the camera to the right just a little??Thanks PB.
Yeah, Murps a perv...but that was Citygirl in the photo. I ain't gonna let all you pervs check out my 16 YO daughter...
Citygirl would probably smack the crap outta me if she knew she was in this thread.![]()
In that case, why didn't ya move the camera to the right just a little??We wouldn't tell, scouts honor!!
what are you doing up so dang early???
