once most of the parts were gathered together... frame & tub got HERCULINED (Herculiner - $99/gallon can at AutoZone).
This Herculiner is awesome, its there for good and forever...
put directly onto the steel after sandblasting (was told thats the best way)
was able to locate new shifter & new boot made by Quadco, although I regret going with the original type of the boot, should have gone with another type - the cut in the middle - slot style - since this one is really tight, and pinched the rubber, explains why it ripps on these machines
cut out the heater core part, and the front part of the doghouse... rest of the front cab is still in tact
something like that...
heater core was pretty plugged up, thus with the noisy heater motor, the core got replaced... all painted and ready to go... blows hard...
front lower sides got trimmed... and rusted flooring redone...
decided to up the floor 1 inch, have aluminum diamond plate put from the inside, and it be removable possibly, for easier access to track in case of necessary repairs.
side walls were cut down, to lower the entry sides., doors will be flush with the floor itself, thus you could clean out the floor pans as needed, by just sweeping it outside without a need for scoop...
towards the back, cut the upper part of the lower sides, reinforced with 3/4 tube, and aligned with overall original lines, to keep things aligned...
I guess going after this kinda look, with some minor changes as usual...
Feel free to comment and ask questions...
