Bull Crap.B_Skurka said:The problem with the new diesel fuel requirements is that it does not lubricate as well as the old stuff.
Viking said:I use the JD diesel fuel conditioner in my new JD 2320. .
I always look for high-volume diesel fuel stations for my PS fuel and change the FF's every 15k and drain the fuel/water separator every 5k.Cityboy said:Greg - What do you suggest with my 6.0 PS Excursion? Do you think diesel additives will prevent problems down the road??I always look for high-volume diesel fuel stations for my PS fuel and change the FF's every 15k and drain the fuel/water separator every 5k.
, thats something allot of people neglect, then they end up with failing injectors
and call the product junk.. Also, what year is your truck? If its an '05 or '06 it has an hour meter on the odometer, make sure you change your oil with the hrs(200max) in mind too(big probelm with fleets) although you shouldnt get there before you reach 3-5,000 for the change.. Keep up with the maintenance and you should be good, and try that additive to see what your results are(I bet you see a difference in fuel economy, noise, and maybe performance).. Let me know if you do have any issues though and I'll see if I cant help, I know the dealers in your area pretty well..Viking said:The added lubricity that an additive like Power Service will provide is probably a good thing especially with the new Ultra Low Sulphur Diesel fuel.
