I'd try a new breaker. I've had a few of them trip like that and won't reset and in all cases it was the 20+ year old breaker itself.No wiring up there that is not inside conduit. So not squirrels.
Had a breaker do that to us a week ago. Wife plugged in a nightlight and the breaker tripped. Breaker would not reset, it would trip as soon as I switched it. Figured out all the outlets on that breaker and unplugged everything (I had missed a couple outlets on the other side of the wall in our game room). Once everything was unplugged the breaker reset like normal. Plugged in everything except that nightlight and all is well. Can't explain why but it worked.But now I have a fuse blown in my family room, storage room and reading nook. Not sure why, nothing is currently plugged into any of the outlets. Breaker may have gone bad? Or something else is shorting it out. I click the breaker and it immediately trips.
Does it cost a lot more to keep feeding it pellets instead of wood? I know the pellets are made of wood so I suppose the chimney needs cleaned same as with wood. Right?
My house is a former display house-burnout I bought in 1976 to flip. Budget to flip for resale was about $24K. We had $7,000. We did the minimum required for occupancy and then moved in. I spent the next few years upgrading everything. Wiring, insulation, HAVC, The house is solid.No wiring up there that is not inside conduit. So not squirrels.
I actually used painters tape on a couple windows and 1 door.
Fortunately BEFORE this storm was even predicted I had put new foam insulation behind a lot of my exterior wall outlet and light switch covers. I'm sure that helped with the breezes. When I built this house I used high efficiency everything; 28 years later it showing its age and needs to be updated. Took a hell of a bad storm to show me how much work I need to do.
