Bombi Basket case
SKINOW11
I recently picked up a Bombi 1 basket case
I cleaned out the inside and sorted the parts...Two 5 gallon buckets of garbage and I need assistance finding the following parts
Track tensioners
drivers door
Window frames
drivers seat pan
brake rotor and attachment items for driveshaft
drive shaft
Wiper arm
Drivetrain
Please message me if you help
BTW I am located in Michigan
I just picked up the new drivetrain...1994 S10 2.2 L Automatic
Please let me know if you know a company that will do a "stand alone" ECM, and any other recommendation to make this work
I thinking about naming the project Bombi 1S10
Now I know why this machine was parked and disassembled...two breaks in the tub from the ram steer
It will be taking a trip to my friend Ted to weld the tub and rust repair
BTW, I am still searching for 2 track tensioners and drivers
Let me know if you have any leads for parts
Those track tensioners are hens teeth. Have you tried Prinoth? I know they can make them for you.
Bob
Thanks! Bobcatbob
Prinoth has the pistons and O rings available but not the housings
I'm thinking about using threaded rod to replace the track tensioners...Anyone else tried this or other ideas?
