This morning was the first time I used my RYOBI 40volt Chain Saw, 14" bar.
Meh, the saw is bulkier and I think a little heavier (with battery) than my little STIHL limbing saw. Just based on size, weight and power I can't give this a "5 Star" review. Maybe more like 3.75 Stars. It just seems to big and too heavy for a 14" saw. If it was a 20" bar it would seem to have a more appropriate size/weight ratio. I did appreciate that it starts instantly, and it is quiet enough to not need ear protectors too. It is handy and for most of my cutting needs will probably replace my gas powered STIHL, even if it is not as good as the STIHL, but because it is far more convenient that the STIHL. This is not a commercial grade/industrial duty saw.
It cut OK, but not great, on a 20' long Locust branch. I was cutting the Locust because we had a branch come down in a storm. Right across a walkway in my back yard. Diameter of the cuts was 3 to 4 inches.
Locust is a dense hard wood, a good bit harder than White Oak, it tends to dull saw blades quickly and clogs sandpaper too. It was no surprise that the saw had some issues cutting the large branch into bite size pieces for the table top fire pit. So maybe a little less power than I had hoped, but again, because this was hard locust, then I might be being a bit too harsh with my criticism.
I have a pine that needs to come down one of these days, perhaps I'll try it on that tree. I suspect with pine it should easily gut through that trunk.
Only got about 8 to 10 cuts in this morning, I was trying to beat the rain. I failed. The rain changed from drizzle to downpour and I abandoned the project, but not before I cleared the thicker part of the branch from the walkway. The battery is still reading as 75+% after the cuts so it should finish off this 20' branch with battery power to spare since the thickest cuts are already done.
