Good return rate to well casing. What is the operating PSI differential? On/off at.... 30/50?......40/60?......You'll be good as long as you don't operate all systems at same time, as all three are fed from a single pair of 1/2" supplies.The shower is basically three separate systems that can be controlled individually. It'll have 3 wall jets for my back when I'm standing. If I'm sitting, that whole system is shut off and just the 2 wall jets and handheld are on. We do have good pressure out here for a well. When we bought the place, the well tested at 1.9 gallons per minute return. The previous owner wanted to guarantee us good pressure and amount of water so he had it drilled down another 50 feet and fracked. Now we're at 5 gallons a minute return.
WHAAAAAAAAAAAAAAAAAT? On TV such flips are done inside and hour.Yes. It does look nice. We wanted something to contrast so it's not too dark. The white tile is also going behind the tub about 4ft up. That'll really help to lighten it up against the dark floor and grey walls. The counters are also going to be darker with some marble effects.
We're going to be in a holding pattern for a while once the shower is tiled and we get the cabinets tub and toilet in place. The counters are ordered but won't be here for about 4 weeks. Once the shower is tiled and all plumbing fixtures are installed, it's another waiting game for the glass to get measured cut and installed.
