He will live again. Just got home with a spare parts transmission and printed up the technical manual for the rebuild....Bummer about the transmission, at least Rusty got you back to the trailer.
GMoose,DAMAGE REPORT - just what you all have been waiting for.
My kitten, first time out since I have owned it, made it about 5 miles on day 1 then we lost the left drive. We did not open up the pontoon to inspect, but based on the behavior I believe we lost the left clutch. Got towed out by the Frandee and loaded into the truck with a come-a-long and a lot of help and muscles.
Next up, Rusty, as has been explained earlier, lost his transmission, but only after some great catting around, and winching a snowmobile up out of a steap drop off. Bonus, he made it out and onto the trailer under his own power. Oh ya, he also had a radiator hose start to leak, but a quick fix by his creator and he was back in action (this was prior to the start of the transmission problem).
The Tucker taper back bent the stearing mechanism but was able to drive out. Cat was taken to town and repaired and welded. Excellent repair since that cat ran the next two days.
Frandee developed a heater core leak, had to shut the supply valve, cold ride after that. Did valve it in once to get warmed up until cab looked like a Chech and Chong movie. Also ripped a third of one grouser wear bar off from one grouser.
Up next, another one for the taper back. Not damage, but a temporary issue. After a stop the left front drive had an ice freeze event which would only allow the drum to rotate about 3/4 of a rotation. After digging snow and ice out, that we could get to, we used a torch and the Muther Tucker, track thawing hose to melt the ice jamb. Before long it thawed and we were on our way.
The 1966 543 had some mystery ignition or fuel issue, but it seemed to move along fine, especially when near red line in the powder.
The Spryte that led us to the top of Mt. Howard, bladeing us a path when needed, walked out of a track. Had to leave it on top of the mountain for the night. We went back this morning and got the track back on, thanks to a lot of great ideas and workers.
I can't believe it, but to my knowledge the Muther Tucker did not break anything, which if you know Rod (aka drive it like you stole it or hell ya I think we can go up that, let's try it). But he doesn't get off free after all. His way cool air lift custom trailer, the coolest one on the planet, has a leaking air valve that needs replaced, sorry Rod.
And lastly, Rob's 443, to my knowledge he wins with no damage, and this cat went everywhere. Congratulations Rob!!!
I hope I got everything correct here, if not please correct me and add what I missed.
Can hardly wait until next year for the Alpine Cat jamboree ADVENTURE. Thanks for putting this on Jesse!
This report comes to you from the passenger seat of my 2001 F350 with a Kitten in the bed and the Frandee in tow out on I-84 with 350 miles behind us and 150 miles in front of us.
The hose is a metalic flex hose about 1-1/2 diameter and maybe 15 ft long. He hooked it to his exhaust and ran the other end to the drain/clean out hole in the side of the pontoon.GMoose,
Sorry to have missed this event this year but just couldn't fit it in. Looks like I missed another good one though.
Just see the pics, but agree Rod's trailer looks pretty cool. Also can you explain track thawing hose? Just curious, sounds intriguing.
You got it right. Thanks for the fun. We got plenty of video footage of you on the first day. We had a blast and will be back next year, fingers crossed!DAMAGE REPORT - just what you all have been waiting for.
Ahh yea, great idea. And I can just imagine him pulling out that hose and hooking it up in the field. Fits right into Mad Max On the Snow theme of his build imo ??The hose is a metalic flex hose about 1-1/2 diameter and maybe 15 ft long. He hooked it to his exhaust and ran the other end to the drain/clean out hole in the side of the pontoon.
factory itemThe hose is a metalic flex hose about 1-1/2 diameter and maybe 15 ft long. He hooked it to his exhaust and ran the other end to the drain/clean out hole in the side of the pontoon.
Me, too. I learned a lot this year at the Jamboree.Wow, I wouldn't have guessed. I'm still in Pontoon 101 ?
Maybe it would be better to rebuild the spare transmission??? Just a thought.Besides the fact that Milwauie Tools should sponsor you. I agree that auto is a good thing. But, I would never trust that trans again. Too many places for that sliver of crap to hide, only to surface out of walking distance.
The same thing might happen to me even after I try to fix it LOL...Crazy ass skillzz. I could break that down, but it would never provide forward motion for anything again!
I think this might answer your question....Maybe it would be better to rebuild the spare transmission??? Just a thought.
A bad seal on the drive drum so the reverse clutch piston was not getting pressure. I spotted it right away when I took it apart. About 1/4 of the seal was destroyed. Looks like it got pinched on installation and eventually failed after sitting a long time not being used so the seal had time to dry out.What was the cause of no reverse in the donor transmission?
You can see in the video me hitting the Kitten with the ski, this is partly because it is hard to see, even though it sticks out front a dozen feet. It is even harder to see the ski when you are going over terrain where the cat is going upward and the ski is going downward.Great video and some of the best kitten video I've seen! Even the tow looked fun. That Frandee is sooo quiet! Also interesting that from the cab of the Frandee, it's still hard to see the end of the steering ski.
Thanks for putting this together. Looks like a neat area.
