peak2peak
Up for sale is a real nice Skidozer with 2579hrs but will go up a little as still using. It's got a Perkins 4cyl turbo diesel paired with an Allison C6 auto. Runs and shifts perfectly with no leaks. Double cab 4 door with ROPS. Everything works great. Tracks in good shape with foam filled tires. Could use a couple new tires but still working fine. Has a a big 6 way blade that is easily removed. Interior is mint with no rips or sign of wear. Has front and rear heat. Cab has no rust or damage but could use a exterior paint job. Passenger lower door window is cracked. This is easily towed and is a real work horse!
I've used it for plowing and backcountry skiing. Asking $23,000 USD
