Time for an update...
So, all in all - purchased mid-September, 2013 and back to factory (upgraded) shape as of mid-December...
Makes that 3 months of garage works: painting, priming, sanding, grindings, blasting, and all that other exciting fun restoration stuff...
Financially it wasnt all that bad - didnt take much time either (vs all the time I've spent last year on the restoration/build of the 1402 Imp).
Anyways - I had a pretty good machine to start with, not much rust & barely any damage...
Everything been gone through - seals/gaskets/o-rings/bearings/springs, etc. were replaced and secured with ALL new neoprene-backed washers (to make it "water-tight"), as well as just gone w/Grade 8 on the hardware...
I figured if it wont be me using it - at least it will last a long time for whomever buys it from me... Build it like for yourself - my motto on the works.
I'll stop boring with the wording and get to the pictures...
Anyone having any questions - just ask, i'll try to answer at my best.
So...
Updated tracks - McLaren brand - almost an inch deep lugs, seem to be a better choice with much more grip in the snow & other softer terrain.
For whatever reason - tracks are actually a bit "sloppy" on the whole setup, I've ended up adding an extra couple of inches to get them to stretch the proper way.
While reading other guy's posts - i've found it to be that I'm not the only one.
cleaned up the fuel tank - replaced the line & fuel filter.
Being a 6gal. capacity - I was told it should last me a whole day of running around (keeping in mind that engine is a 4 stroke Kohler25)...
Anyone with a different experience - chime in - and comment...
Previous owner slapped together a pretty HEAVY duty (literally) tranny to engine mounting plate... in turn - I was able to cut out 2 large squares out of the sides (in total weight over 5lbs) - and still maintain rigidity.
other than an overall paint job - the hydrostat tranny got slightly rebuild - new seals/gaskets, etc.
pretty much whole thing together... and ready for fresh oil...
and this is how finished product looks after having the STAGE 1 phase completed...
if anyone wondering on the exhaust - its pretty tight & not much shaky-time...
I figured that it was perfect to keep it this way - to warm some hands if need be after a cold run, as well as blow to the side, rather than keeping all that extra heat under the hood... After few runs, I might be adding an extra fan or two into the compartment under the hood if it isnt going to be sufficient as is... (there is a fan on the heat exchanger of the hydrostat.
accessories & gauges...
Everyone love those... had to add an hour meter (to fill in an already cut hole in the plastic), as well as added a volt meter to keep me away from worrying on a discharge on the battery.
Regular 12V plug-in is a good idea now days with all the devices, as well as a dual port (water-proofed plug) for those USB chargeable devices like iStuff (iPhone/iPad (GPS)), Camera Equipment (GoPro/DSLR) and other junk...
I've actually been looking at a nice solar battery tender setup - might be a great addition to tender the battery & keep it topped off...
Switches are watersealed, 2 on the left for front/rear & side lighting, and a switch by the ignition for the heat exchanger's fan.
Have found that Optima's YellowTop overall serves the purpose, never caused any issues, and considering that I've installed them almost in every own vehicle or toy - local guys at AutoZone replace them if any gave me trouble... (only one has - and it was my fault that it did)
Plus - a 4000lbs winch will be mounted at the front (possibly with a hitch receiver type mount) - I will use the extra juice that YellowTop puts out
under the hood...
electricals are very important, when it comes to open snow/rain type equipment, so this is what was used...
A 911CIRCUIT fusebox with relays, so nothing gives us trouble - and I believe everything got its own fuse... I've been blessed to have the wiring done by one of the guys that "runs & creates" the brand, so top of the line treatment here...
and this is whats powering the whole thing - in case anyone wondering...
and a video to follow it up...
[ame="http://www.youtube.com/watch?v=MUnl0ZYOPCA"]Cushman Trackster overview - YouTube[/ame]
