I want to build a lean-to style greenhouse on the back side of my garage/workshop. STILL IN THOUGHT PROCESS STAGES. The long wall will have a western exposure. Looking at 8' by 20' for the size. The ground is pretty darn close to flat, but just enough slope away from the foundation to allow for drainage.
I'm thinking that I will hit the grass with killer, then dump some crushed limestone on top a couple inches thick for stability. drainage and to make it easy to level, then use pressure-treated lumber for the foundation. The new pressure treated lumber is non-arsenic and rated for ground contact. Probably drill a few holes in the PT lumber and drive down some re-bar to act as an anchor.
Does this seem reasonable?
