Ski Fischer
For Sale:
The Cat: 1983 Pisten Bully PB060DR (similar to a 70); 5237hrs; 2 stick, Hydrostatic drive(Min-Max MPH 0-~10); Mercedes OM616 four-cylinder diesel (71hp @ under 2gal/hr diesel consumption); 12volt system; Auxiliary hydraulics have been removed from cat and are not in my possession. Interior excellent; Exterior good (some surface rust above rear window, Aluminum decking warped) Track belting is spliced and dependable, New (2013) refurbished Fall-Line sprockets. No frame cracks present or repairs to frame have been conducted. Very clean, mechanically sound machine that has fresh filters and oils throughout (2013 or <10hrs).
108"YTS Ginzu: 108" steel frame YTS Ginzu with low use. Twin electric track setters, Custom transport wheels/frame (manually operated), Custom pintle ring/lunette for adjusting hitching height and tongue length.
The Roller: 84" x 24" diameter roller (94" total width); Integrated wiring harness to be used with or with Ginzu. Great for packing down early snow fall. Actually, the combination helps reduce the bridging of snow/ice in front of ginzu knifes.
Dimensions: Snowcat- 85"wide, 124" long, 84" tall (4200 lbs); Ginzu 108"; Roller 84" x 24" dia., 94"frame width, 80" total length.
Entire snowcat with attachments coupled measure 27'. Possible to get length to 24' for transporting on trailer.
All equipment is "turn key", ready to operate confidently as pictured. I used this machine, with excellent results, to groom for State High School classic race and local club's 15k fundraiser classic race. Great system for club or owner operator with narrow trails. I am selling because this is a lot of machine for two uses per season.
I have a Valley brand 10way push frame for a push blade that can attach to snowcats OEM blade mounts. However, I do not yet have a U-blade or the auxiliary hydraulics for this application.
Located near Mt. Hood, Oregon. 97041
$28,000 for PB060DR, 108" Steel Ginzu w/ 2 track setters, 84" roller, Valley blade frame. Absolutely no interest in selling separate items. I am very willing to help with loading for your arranged transportation of this equipment. Contact Harold fischerhl@gmail.com
Full size pictures at the following link:
http://s1302.photobucket.com/user/Harold_Fischer/media/P1000169_zps2701ef4a.jpg.html?sort=3&o=3
