newhampshirefarms
Selling my Nodwell for $5,500 firm or interesting trade. I’m in Rochester NH. Only 8ft wide so easy to transport/trailer. It runs and drives but needs restoration. Hasn’t been driven much this season since it has lost the rubber on the front idler wheel.
See video 1 (Walk around)
and video 2 (Driving)
I believe this is a 1972 or 1973 maybe? Winch works. Sold as-is. Tires worn/ripped, front idler wheel on one side missing rubber, tune up suggested, brake reservoir on one side needs refilling frequently. Clutch questionable as I stop and shift then start in gear as it seems to want to grind otherwise even with clutch pedal in. Clutch or the hydraulic line it uses should be looked at. Exhaust pipe should be extended, rain capped etc. Some cab rust. These are very rugged go-anywhere machines made in Canada.
