telbert
Cushman Trackster, not sure what year, does it matter? Ran when parked, they're known for 1 cylinder running lean and going bad. This happened to this machine, and I replaced piston/cylinder with a used one. Put lots more hours on it, but can't say how much life is left. Will run, but needs old fuel cleaned out and carb, etc. gone through. Some gel coat damage, see pics.
Comes with NOS and used parts, see photos. Good used tracks, 2 hydrostats 1 right and 1 left, 20 bogie wheels (surface rust), 4 bogie axles, 25 bogie seals, primer pumps, spark plugs (10), filters hyd air and fuel, mufflers and their mounting hardware, starter w/bracket, pulleys, fuel pumps, ign amplifiers (1 maybe bad), used block,cylinders,shroud,reeds. Magneto, points, coils, plug wires New windshield, frame, side pieces and vinyl. 4 new torsilastics. Manual, air box. Non stock blade with winch. Has clips to lockout hydrostats. Zoom in on the pics, view the part numbers. Too much to list.
Asking $3500 for all of it. Located in Big Bear Lake, SoCal.
