Any and ALL Builders
1990 LMC 3700C This machine just had a major overhaul. Here are some of the specs. 3208 cat rebuilt about 1000 hrs ago runs perfect. hydro system flush all new filters. Rebuild drives and pumps about 300hrs ago. All tires are rubber filed and in good condition 3 new. All new belting for tracks 15-20 hrs on tracks pioneer cd player with Ipod or iphone charger and for music. 50 watt vhf-uhf radio. 7inch LCD Tv in cab for rear back up camera and in cab camera both have night vision and audio. The screen can play movies off your iphone or DVD.Custom 8 foot wide by 10 foot passenger cabin. The cabin is solid Aluminum and built solid.It has 10 windows for great views. The cabin has to interior lights 2 back up flood lights 2 left side floods 2 right side floods and 2 forward floods. Large led flashing light bar can be seen 360 degrees 2 led amber running lights on each side and 2 red led running lights on back. There is a load light on the back of the cabin just for the back door and stairway. The cab is not insulated its all polished aluminum with brand new upholstered seats. The cabin seats 9 comfortable. Its heated and will bring it to 85 degrees in a heartbeat the heater is controlled from inside the passenger cab. Inside has a camera to watch passengers and audio to listen to the passengers it also has night vision. The cabin has a sight window for hydro levels and a window that backs up to the cab window so you can see through the cabin. The cabin has 2 diamond plate tool boxes for storage for tools and fluid and emergency gear. There is also a emergency door that is 3 foot by 3 foot leading out on the tracks. On the back is also a roof ladder. There is a access panel in the floor to check hydro ports and batteries. The electrical system on the cab is all brand new and the charging system and batteries on the cat are all brand new. The cabin wiring was wired through a 7 pin ford truck trailer adapter so 8 bolts and unplug the cabin can be on the ground in less than 20 min. and back on in less than 30 min. The cat tub was painted gloss black and so was the blade. the cab was vinyl wrapped in digital snow camo. The cab headlights are 7 inch HID They turn night into white daylight no joke. The cat tracks have been cut down so overall width is 11'10" also it has been to shorted to 10' 2" so its under 13' 6" for transport. This machine will still go through the deepest powder you can throw at it. All filters on the 3208 cat have been changed and just were serviced. It has the third pump for a tiller but no tiller just a back drag 13 foot wide can be cut down stainless steal. The cat came with a 12 way blade but currently is 10 way. All wheel bearings are brand new and races. all with synthetic grease. The cat has a Green sticker registered in California till 2013 and I have a California title in hand free and clear. This list could continue I have a lot of money in this machine plans changed forced to sell asking $28,000 the machine is located in northern California and still in the snow for test drive for serious buyer's 209-304-5078 anyandallbuilders@yahoo.com
