WTS 1979 Bombi
79bombi
Site Supporter
1979 Bombi for Sale
$6.400
Have run out of time to work on/play with
steve@highmountainsports.com
located in Western Maryland (21541)
Pictures https://picasaweb.google.com/Highmt...authkey=Gv1sRgCJrUtv6sheqqqAE&feat=directlink
Has sat for a year since I broke the sprockets. Just put new sprockets on 4/2011
Mostly garage stored – kept it in the yard some winters
It probably has less than 40 hours on it since I bought it
Hour meter broke at 311 hours
I groomed with a roller for a couple of hours
2” ball barrel groomer with a follow behind board with groomer combs included
Generator
Rear Winch
Yakima Rack with ski/snowboard rack
I have a brush guard for it (has not been refinished)
Includes all pictures/receipts/documents I have on it
Differential cooling pump
I bought this in March 2004
I pretty much pulled it apart and redid it.
At that time;
New sprockets
Some belt splices
Repainted cat/took apart
New tires
Foam filled tires
New Hela front and generic rear lights
Replaced a lot of hardware including door locks (have keys)
New window seals front and rear
All new wheel bearings
Rebuilt Differential with new ring and pinion
Current work needed:
Carb runs rough (just put some sea foam in it)
Disc brake needs adjustment (ran it several summers ago with parking brake on – duh)
Track belting is aged but usable
Need window latch for one window (currently taped shut)
Need trim plate for one light
Right passenger seat needs mounts rewelded
Left foot rest needs rewelded/worked on
