WTB Engine wiring harness 91 LMC 1500 (Ford 300)
If you don't find one, would it be that hard to make up one? If I am not mistaken you engine is carborated, and has little to no electronics to bother you. With a simple wiring diagram, you should be able to make up your own.
But if by chance you find what you are looking for, it would be easier....
No making one would actually be pretty easy once you had all the correct connectors. I'm actually own a radio electronics business but I just don't have the time to search for the materials and make it.
You should be able to adapt one from a pickup around the same year. Maybe use a terminal block to make your connections to your existing one.
