WTB Dozer blade for Muskeg tractor
DynatracGuy
I need blade and side "arms" for a 70's Muskeg tractor. It is a wide track version with double D tracks. Even pictures would help, I can make it from scratch if necessary. So far the only thing I have to go on is sales brochure showing the optional blade. The attachment points on the outer boggie support frames are there. I can implement the hydraulics myself.
timandkim
a factory leon blade fits on very easy and pushes off the frame it also doesn make your machine any wider , wich is a big bonus in the bush . we used one a few years ago with a original blade and found the side arms a real disadvantage in the deep stuff .
tim
DynatracGuy
Thanks for all the feedback. I can see why a front mount is better than the original side arm design. I have the factory pto driven winch on front of my Muskeg. I think I will temporarily remove the winch and use the frame for it to mount blade. I have a half decent shop and will make it myself. A 12volt hydraulic power pack and a cylinder will supply the lift. I'll share the design after I verify that it works properly. Won't be this winter, I have to live within my budget. I have a Ranger V with 6' blade for snow clearing this winter.
MNoutdoors RIP
DynatracGuy
Darn, it would interfere with the front which mount. I'd have to cut it off, not something I want to do. I guess I'll have to use a mount similiar to mount used on pickups for snow plows. Thanks anyhow, I'll bet someone will buy the whole setup pretty quickly with all the snow.
